Howdy folks,
Greetings from North Idaho on the shores of Lake Pend Oreille. My apologies if this is a duplicate post, but I have not been able to locate the question that I posted during the weekend.
I am building a 40" hemispherical oven dome and I have a question regarding the upper brick courses in the oven dome.
Is it better to taper the bricks for each course (for strength and/or insulation) as compared to keeping a straight edge and having an angled gap between the bricks within a course? Obviously, not having to taper each brick is a lot easier (although you end up using more mortar).
Also, I assume that I should progressively decrease the brick width for each course of bricks (for better fit to the course below it). Is this correct?
Thank you for your assistance.
Good Roads
Harpist
Good Roads
Harpist
