kiln shelf for cook floor
  • waynebergman
    • Jul 2007
    • 138
    This Kiln Shelf I recently got is working good for a cook surface. I bought these as two cemi circles as the single piece would be too big to fit in oven doorway. I then welded two seperate rings of mild steel around them to hold them together so they dont seperate if you bang them with the peel when working the oven. The rings were made of two diferent widths so one side of the floor can kind of have a dam or lip to stop pizza from sliding into fire and ashes when working with the peel and then the other side that is lower is the side I brush the floor clean to. So far its working good and the kiln shelving only cost around 5o bucks. If it breaks or gets worn I can just replace it easy eneough. It is kind of nice to have the cook suface a bit raised of the ground as when coals are raked off to the side they dont fall back into the food area so easily.
    Our oven is now about 1 and a half years old and I am proud to say it is still working quite well. We have actually had standing ovations from our pizza eating guests. Thanks again Forno Bravo for the plans and suport for the build and research on this project.....wayne
    see below for my oven album of progress to date
    http://picasaweb.google.com/wayneber...PizzaOvenWorld
  • Lburou
    • Dec 2010
    • 1165
    Re: kiln shelf for cook floor
    A novel idea, do you have more pictures, I'm having trouble conceptualizing everything you said.
    Lee B.
    DFW area, Texas, USA
    • brickie in oz
      • 3445
      But isnt the oven floor a cooking surface? or an I missing something?
      • RTflorida
        • Jan 2007
        • 1446
        Bare firebrick floor has worked fine for me the past 3 1/2 yrs. Ash has not been a problem, it has already been brushed away before pizzas go in. I guess to each his own...some folks like to cook their pizza in a pan or start it in a pan, I don't understand that concept either.
        RT
        • waynespizzaworld
          • Jan 2011
          • 95
          sorry for the late reply....I just stumbled on this and forgot I posted it.
          I will try and explain my thinking here and how it works for me. I have found with my 36 inch internal cook size it is a bit small with the coals and fire swept to the side the coals kind of drift back into the cook area and with this raised up cook floor it kind of acts as a bit of a dam or raised up area off of the brick floor so coals dont fall back into the pizza and it gives me a better defined area that is the cook area and what is the fire area.
          And yes it is the same make up as the floor or close enough. So as it is show it just stay there both during the initial firing and after fire and coals are swept aside I just cook right on the 1 inch thick kiln shelf.
          I am happy with it and find it easier to keep clean and seperate the cook area from the ashes etc.
          May not be for everyone but I like it.
          Oh I forgot to mention I am registered with a diferent name now as I forgot my password etc. It has been a while since I have been to the site.
          Step by Step of Oven #2 Build... I have built this one in partnership with a friend for a customer that took a liking to my first oven https://picasaweb.google.com/waynebe...42PompeiiOven#
          • brickie in oz
            • 3445
            I can see ash on your all new raised cooking floor in the pic.
            Maybe it should be higher?
            • Lburou
              • Dec 2010
              • 1165
              I'd eat that pizza, ash or no ash
              If somebody doesn't think outside the box, nothing will ever get better.
              Lee B.
              • brickie in oz
                • 3445
                True, Ive eaten a lot worse, besides, isnt ash good for you?
                • RTflorida
                  • Jan 2007
                  • 1446
                  Isn't ash considered high fiber? Or as my grandmother would say - 'roughage'
                  In any case, it just adds to the rustic appeal.
                  RT
                  • brickie in oz
                    • 3445
                    From now on I going to eat nothing but ash pizzas.
                    Just kidding....
                    • texassourdough
                      • Nov 2006
                      • 1719
                      From what I have heard kiln shelves often have coatings on the top that are not for human consumption - a variety of bad chemicals. The bottoms are usually not coated from what I heard. It would be wise to get details on your shelf!
