how are you notching your bricks
  • tifosi
    • Jul 2009
    • 52
    trying to figure the best way to make small cuts with the HF saw, specifically trying to make the notch for the door to lean against, some refer to this as the pistol cut. is there a trick since with the 10 in round blade its hard to make a 1/2 inch cut
    Re: how are you notching your bricks
    The only cuts that are hard to make are the really deep cuts, sometimes you have to score those on both side, break off the segment, and trim it freehand. The shallow half inch cut you're taking about, you can just mark the line with a waterproof marker, and pull the table away and cut it freehand. This presupposes that you're using an unsegmented diamond blade where brushing against the blade won't be a disaster.
    • tifosi
      • Jul 2009
      • 52
      that is what I thought, yes smooth blade, will need to watch my fingers still
      • Les
        • Sep 2005
        • 2945
        Tifosi,
        I ran a cut to the depth I needed. I was using a HF saw so I could raise the blade to make the second cut (of the pistol). On the really long cuts I believe I ended up using the blade as a "mil" to finish the cut. You can see the results here. PhotoPlog - Uploads Posted By Les
        Good luck,
        Les...
