Oven Curing
  • Evets
    • Nov 2009
    • 55
    Oven Curing
    I know the plans state that the oven should be cured after it's completed, but does anyone think it would be a good idea to cure the oven, at least somewhat, before the insulation blanket is installed, and again after the blanket and vermicrete shell? It just seems to me that it would dry more completely, more easily that way.
    I'm nearing this point in my build and I just want to do what's best. Thanks.
    Build Thread, http://www.fornobravo.com/forum/f8/e...-pa-13750.html
  • SCChris
    • Jun 2009
    • 1213
    Re: Oven Curing
    This forum area will have many answers to your questions about curing.
    http://www.fornobravo.com/forum/f16/...uring-767.html
    My opinion is that some low temp curing without a insulation makes sense. Once you get your oven temps up over 212F 100C I'd start to look at insulation so the oven heats cures evenly. My reasoning is that the more even the heating during curing the less cracking.
    Take a look at the "Firing your oven" Forum, you'll find all sorts of info there.
    Chris
    • Evets
      • Nov 2009
      • 55
      Re: Oven Curing
      Thanks Chris. I don't know how I missed that forum.
      • SCChris
        • Jun 2009
        • 1213
        Re: Oven Curing
        No Worries!
        C
