Home made timber pizza peel.
  • brickie in oz
    • 3445
    Here is a timber peel I made out of Celery Top Pine, not a true pine but its used a lot in boat building in Tasmania Au, it cuts and works like pine.
  • heliman
    • Sep 2009
    • 1181
    Re: Home made timber pizza peel.
    Nice - good size too for making extra large pizzas...
    / Rossco
    • Faith In Virginia
      • Oct 2010
      • 713
      Very nice!!!
      I made three peels but I used hard maple. I will show a picture as soon as I take one.
      • fxpose
        • Jul 2009
        • 942
        Very nice craftsmanship on that peel!
        George
        My 34" WFO build
        • azpizzanut
          • Aug 2010
          • 397
          Hello All,
          Is there a recommended wood that is good for a peel? My city has several hardwood supply stores and a variety of woods available at Lowe's and Home Depot. I think a straight grained wood that is lightweight and not sappy would be useful. Basswood, poplar, alder, come to mind, but there must be others that meet our needs too. What are your thoughts for a first time peel project? Thickness, dimensions, etc.
          Cheers,
          Bob
          • Alter ego
            • Aug 2009
            • 186
            I made 4 peels from 6mm plywood. On either side of the handles I put 2 strips of 40x20 rounded Tassie oak trim which makes them easier to hold and ridgid enough to use. To make them a bit more waterproof and allow me to wash them down I rubbed a couple of coats of olive oil into them before using them.
            It is now much easier to make up multiple pizzas and place them in the oven to cook. I still use my metal peel to turn & remove. I'll add a couple of pics later
            Paul
            • brickie in oz
              • 3445
              I thought about ply but was concerned about the chemicals leeching from it into the pizzas.
              • Alter ego
                • Aug 2009
                • 186
                I'll let you know if it kills me I don't think that the dough stays on there long enough to be a problem.
                Paul
                • Tscarborough
                  • Oct 2009
                  • 3341
                  That is a lovely peel, the only thing it is missing is a pizza upon it.
                  • brickie in oz
                    • 3445
                    I was more concerned about the heat of the oven driving off the nasties.
                    • brickie in oz
                      • 3445
                      Thanks guys, Ill have another pizzafest shortly and post some more pics of the peel in action.
                      • Alter ego
                        • Aug 2009
                        • 186
                        I just use my plywood peels to place the pizza in the oven so it is only in there for 5 seconds. With multiple peels I can make several pizzas and pop 3 in the oven at once to cook. I find it much easier to feed larger crowds this way.
                        Paul
                        • Big E
                          • Nov 2010
                          • 5
                          Very nice work!
