Heat Break
  • brickie in oz
    • 3445
    Heat Break
    To break or not to break, that is the question.
    Or it was until I did it on the new oven..
    The fire embers inside have been soaking for about 2 hours and the oven is 400c.
    The pics below are self explanatory.
    I used insulating fire bricks between the oven and outer skin on the front only and in the flue below the damper, the damper is also insulating fire bricks.
    There is a ceramic rope in between the heath and the granite tiles.
    The build, http://www.fornobravo.com/forum/f44/...two-15241.html
    Hearth (by the door), 130c.
    Granite, 115c.
    Fire Brick, 223c.
    Insulating Brick, 93c.
  • ThermoJax
    • Jul 2010
    • 168
    Re: Heat Break
    Well done !! A great proof of concept.
    • Tman1
      • Aug 2010
      • 346
      Re: Heat Break
      Awesome info!
      My oven (for now):
      http://www.fornobravo.com/forum/f43/...ven-14269.html
      • Les
        • Sep 2005
        • 2945
        Re: Heat Break
        Is this really needed?? The brick doesn't conduct heat all that well. In regard to the flue, I would think that the hotter the better for draft. You got me curious though. Next time I get to temp I want to see the delta between the interior floor and a few inches away on the landing.
          • 9214
          Re: Heat Break
          There are three advantages in having an insulated gap.
          1. Reduction in heat conduction and consequent heat loss.
          2. The expansion joint reduces or eliminates any outward pressure on the exterior arch.
          3. Reduces the temp. differential between the inner and outer surfaces of the outer arch thus reducing thermal expansion stresses.
          Hands up those who have cracks in their outer arches. I bet you don't have a thermal break.
          • Lburou
            • Dec 2010
            • 1165
            Re: Heat Break
            I'm planning an arch of insulated firebrick (IFB) just outside my inner arch. Then, an air gap between the brick landing floor and the granite in the front two thirds of the oven landing. I've placed rigid insulation between the firebrick at the front of the oven landing and the support for the granite landing (attachments one and two). The air gap between the firebrick and granite will be less than one sixteenth of an inch (to be filled with ash).
            Will study incorporating IFB in the chimney structure Brickie...Great 'Demonstration/Validation' phase! What I'm not clear about is your IFB placement and how you protect the inside edge of the IFB as you run a peel through there......? In other words, is the inside IFB edge out in the open? I'm working on that issue.
            Lee B.
            DFW area, Texas, USA
            • Les
              • Sep 2005
              • 2945
              Re: Heat Break
              I just checked an I have zero cracks at that location. Maybe I am lucky. I did notice a crack on one of my porcelain tiles, but that was from freezing, about 4 foot from the entry.
              • Lburou
                • Dec 2010
                • 1165
                Re: Heat Break
                My goal in using a heat break is to maximize heat retention (read minimize heat loss) for extended baking, after the pizza bake. There is one other issue. That is the hot summers in Texas. The heat break, and less radiated heat from the landing, should make it a little more tolerable while standing in front of the hot oven in the heat of summer........I know, I live in my own dream world
                Goal is not to minimize cracks, I already have cracks and haven't fired the oven yet
                Lee B.
                • brickie in oz
                  • 3445
                  Re: Heat Break
                  You can see the insulating halves in the dry set out I did before I built the oven.
                  • brickie in oz
                    • 3445
                    Re: Heat Break
                    Tonight's effort.
                    Ambient, 21c
                    Granite, 55c
                    Hearth, 120c
                    Fire Brick, rebate (near the entry) 300c
                    Insulators ,(near the entry) 150c
                    Oven, 700c
                    Back of the ceramic blanket that surrounds the oven, 27c
                    Front entry arch 30c
                    The last oven was too hot to touch at times, this one isnt.
                    • Lburou
                      • Dec 2010
                      • 1165
                      Re: Heat Break
                      I see Brickie!! Thanks
                      Your demonstration here firms my resolve to make a heat break in my oven. I couldn't be more happy with your timing.
                      Lee B.
