I have been going along quite well and have finished chain 8 and my inner arch.
Now I am having a bugger of a time getting chain 9 started.
On all previous chains there has been some structure at the start of the chain to set the first brick against. i.e. the form for the inner arch.
Now I am trying to start a chain and I now have a completely open circle. When i set the first brick all is fine; my indispensable tool is working well to hold the brick in place and all looks good.
Then I go to set brick number two and I keep knocking brick number one loose when I try and tap brick two into place.
I need help is there some trick that someone has learned to get an upper chain started?
The idea Ihave (which will really slow progress) is to set brick one and wait a couple of hours and then continue with the chain. or to set brick one the night before I want to start a new chain but that seems ridiculous.
Chip
Chip
