hi all, i am at the final stages of my wfo, in that, the base and dome just need finishing touches to them. i would like to finish my dome (which will be exposed to the elements)with marble pieces glued to the outer skin of oven. I put on a single coat of render so far (about 1/2 to 3/4 inch thick) which was made up of 6:1:1 white washed sand : cement: lime and a little bond crete with fibreglass strands spread through over dome. I was going to put another render layer over but i have read it is mainly for getting the desired shape , which i already have, and then glue on marble pieces. My question is do i need another render layer,how do i get the oven waterproof and will that be ok when i go to stick on my marble pieces with tile adhesive?
cheers,
Tony
I can nearly see the light!
cheers,
Tony
