Robot Coupe for dough
  • Robot Coupe for dough
    Has anyone heard or have experience using a Robot Coupe to mix dough?
    OK based on the below comment I thought I better post a picture or two.
    Chip
    Chip
    Re: Robot Coupe for dough
    Ive got a chicken coupe that is good for dough when it fails.....
    My Build.
    Books.
      Of course humanoids use Robot Coupes and food processors to mix dough. And they probably use them to mix wallpaper paste. But that doesn't mean they are worth a %^#& You can do a better job with a variable speed electric drill and a home made dough hook.
      The problem is very simple. Overworked, overheated, oxidized dough. It's fine for people who want to make mediocre, tasteless dough in an hour but it will have the qualities of fine cardboard with a tight crumb and none of the unique nature most of us look for in dough for a WFO. Taste, etc. will be substantially impaired. There is nothing gentle about a Robot Coupe (great food processor by the way). It has only one speed and the dough doesn't have a chance. It will be beaten to a pulp, torn, and destroyed within 20 to 30 seconds.
      Feel free to try to prove me wrong! But you won't build a reputation as a great WFO pizzaiolo using food processor dough!
        The problem is very simple. Overworked, overheated, oxidized dough. It's fine for people who want to make mediocre, tasteless dough in an hour but it will have the qualities of fine cardboard with a tight crumb and none of the unique nature most of us look for in dough for a WFO. Taste, etc. will be substantially impaired. There is nothing gentle about a Robot Coupe (great food processor by the way) and the dough doesn't have a chance.
        Glad I asked, I found a deal on a commercial model and I will pass. Thanks.
        Chip
        Chip
          I used to use dough hook on a kenwood chef and it was acceptable for making dough but since I started hand kneading the dough I wouldn't go back to any mechanical device. The quality of the finished dough is way superior. The exercise isn't bad either.
          Tom
            Unless you kneaded 5kilos or more each time on a daily basis.
              Hand kneading actually works pretty well up to at least 10 kilos/25 pounds and there are people who go far higher. It can be far less messy than a mixer though it does require a bit more attention. The only mixers IMO that can match hand mixing are a spiral or a fork and they are specialty mixers that are $$$, Some people think the Electrolux is near comparable but I have not been able to try one so....
              I was trying to be funny Chip but I wanted to emphasize how bad the dough is relative to hand or minimally mixed dough. And I long ago made a batch of dough to verify how bad it was so my "rant" was not just theoretical!
              Do it by hand. It is SO easy once you get the hang of it!
              Bake on!
              Jay
