I have started my build of a 42" in Portland, OR and have been very impressed with some of the builds on here. I would like to put the time in to cut the bricks for a nice, tight taper, but can't seem to figure out how to set it up on my saw.
I have reviewed a number of threads about cutting the brick faces to remove the inverted Vee, but haven't been able to figure out how it is possible to cut the taper without running into the arbor on my 10" wet saw.
Is there some trick that I am missing, or is this only possible with a 14" saw?
Also, I have read that people soak the brick prior to cutting. Is there a reason for this? I cut the bricks for the floor without soaking, and the diamond blade cut through it like butter!
Thanks for all the help.
Aaron
Aaron
