Harringbone Pattern
  • thebigt
    • Jun 2012
    • 157
    Harringbone Pattern
    So the oven plans that I have call for harringbone pattern for the hearth. Is there any advantage to doing this to make the extra work worthwhile?
  • thebigt
    • Jun 2012
    • 157
    Re: Harringbone Pattern
    Originally posted by Karangi Dude
    Setting the hearth bricks in a herringbone pattern at 45 degrees will alleviate problems like the peel, pots or pans from catching on the joins.
    Thanks sounds like its a good idea to do then. I will incorporate it into my build this summer
    • nissanneill
      • Apr 2007
      • 1886
      The big T
      I really don't understand where your thoughts are mate!
      How much extra work is there from laying the bricks in a Herringbone pattern, Stacked bond or as a brick wall pattern, known as Running Bond.
      See the pattern alternatives here:
      Patio Brick Patterns
      Cheers.
      Neill’s Pompeiii #1
      Neill’s kitchen underway
