Harringbone Pattern
  • nissanneill
    Re: Harringbone Pattern
    The big T
    Is there any advantage to doing this to make the extra work worthwhile?
    I really don't understand where your thoughts are mate!
    How much extra work is there from laying the bricks in a Herringbone pattern, Stacked bond or as a brick wall pattern, known as Running Bond.
    See the pattern alternatives here:
    Patio Brick Patterns
    Cheers.
    Neill
  • thebigt
    Originally posted by Karangi Dude
    Setting the hearth bricks in a herringbone pattern at 45 degrees will alleviate problems like the peel, pots or pans from catching on the joins.
    Thanks sounds like its a good idea to do then. I will incorporate it into my build this summer
  • thebigt
    started a topic Harringbone Pattern
    Harringbone Pattern
    So the oven plans that I have call for harringbone pattern for the hearth. Is there any advantage to doing this to make the extra work worthwhile?
