Any reason, other than dust, I cannot use my 14" abrasive chop saw mounted with a diamond blade for dry cutting concrete blocks and bricks? I have a squirrel cage blower I can use to help with dust.
Re: Using a 14" saw
It will be a mess. I would try to avoid having the grit get inside the motor. Also, soaking the brick may help a bit.Check out my pictures here:
Re: Using a 14" saw
It's pretty common practice and very dusty, so wear a respirator or good dust mask. Don't bother soaking your brick or block though, it won't do anything... not trying to sound contrary to you here, Les...you will still get the dust anyway. Wet sawing isn't an option or are just trying to use what you have?Old World Stone & Garden
John Ruskin
Re: Using a 14" saw
Originally posted by Mudologist View PostYou'll still get dust, but soaking will help some, and the blade will last longer.Old World Stone & Garden
John Ruskin
Re: Using a 14" saw
Originally posted by stonecutter View PostMaybe, if bricks held as much water as a sponge.Check out my pictures here:
Re: Using a 14" saw
Originally posted by Les View PostIts funny that you say that. Fire brick is incredibly soft and porous, left in water it will pretty much get wet. Total opposite of a stone like granite or marble. I had a wet saw but for grins I dropped a brick in water for a few minutes - when I sliced it the water had penetrated about a quarter of an inch. Anything to minimize the dust will helpOld World Stone & Garden
John Ruskin
