Oven Brush
  • Wyatt Earp
    • Oct 2012
    • 15
    Oven Brush
    I bought a Copper brissle brush from Forno Bravo. Now I want to buy a smaller hand held brush for cleaning within arms reach. Problem is the only brushes I can find are brass. Will this work? Or should I buy another Copper brush?
  • Les
    • Sep 2005
    • 2945
    Re: Oven Brush
    The only brushes I have used are brass - no worries...
    • nissanneill
      • Apr 2007
      • 1886
      Re: Oven Brush
      Wyatt Earp,
      that's what brass is, copper and zinc, ideal for that application.
      I have gone through 2 natural bristle brushes without setting them alight, but there is no other alternatives.
      Cheers.
      Neill’s Pompeiii #1
      Neill’s kitchen underway
        Re: Oven Brush
        I find a blow pipe is a far more effective tool than a brush. You can also use it as a poker and to reignite the flame if it dies
        • Laurentius
          • Nov 2010
          • 923
          Re: Oven Brush
          Hi Wyatt,
          Glad to have you here. How's the Daltons and Virgil?
          • Les
            • Sep 2005
            • 2945
            Re: Oven Brush
            How does that remove burnt cheese? I find myself using the brush more than I should
            Neill, agreed - but Wyatt said he had a copper brush, they are two different things. That's like saying hydrogen is water. I thought all the oven brushes were brass?
              Re: Oven Brush
              I use a pizza peel with a flat leading edge. Way more effective than a brush.
              • brickie in oz
                • 3445
                Re: Oven Brush
                Just crank up the heat, the cheese dont stand a chance.....
                • Bacterium
                  • Apr 2007
                  • 560
                  Re: Oven Brush
                  Yep rake some coals over the top and then rake aside a few minutes later and then I brush the floor with the wet mop.
                  Damon
                  Build #1
                  Build #2 (Current)
