I didn't see a tools thread on here, sorry if I missed it.
I really like tools and I imagine most people who decide to build their own wood fired oven probably do too. I'd like to start a list of tools that work, tools that don't, tools you made, etc. I know there are a few specific threads on the latter topic.
This moment, I'm looking for the best style of angle grinder diamond wheel for brick and/or concrete. I can't seem to find any information about which diamond segment pattern is appropriate for what material. dual row, "turbo", T segment, V segment, etc. It seems a number of you use these, which style wheel did you buy? what grinder are you using? has anyone used them wet? I was thinking of using the 3gph submersible pump and a section of loc-line to flood cool the wheel
So far, the current model Harbor freight 10" tile/brick saw has served me well. I did buy the legs for it, which was a wise move, I think. it made it a lot easier to get in and out of the garage and set up. I'm using a 10" rigid segmented blade from Home Depot, it's between 1/4 and 1/3 used in approx 250 cuts of common brick, and if anything that's a low number. I believe it was $65 with tax, and I chose it over the harbor freight non segmented(all they offer, $30) because the reviews said they don't last. Favourite 10" diamond blades?
I also can't say enough how helpful a rub brick is for cleaning up uneven mortar for us amateurs
I also used it extensively on the block stand to take the rough casting flash off the tops of the CMUs so the level would sit flat on top and give a true reading.
What other tools have you found invaluable on your build?
I also used it extensively on the block stand to take the rough casting flash off the tops of the CMUs so the level would sit flat on top and give a true reading.What other tools have you found invaluable on your build?
