Crack
  • brickie in oz
    Re: Crack
    I got a very small hairline crack in mine when I first fired it, while its not a problem structurally it bugged the hell out of me.
    I racked out the joint to a depth of 5mm, moistened the joint and refilled it, it hasnt reappeared.
  • stonecutter
    Re: Crack
    Leave it....a mortar parge wont hold.
  • Filthymutt
    started a topic Crack
    Crack
    After the massive fire. The dome itself was fine but I got a crack in my outer arch.
    Maybe 1mm between a brick on the left side of the arch and it's mortar joint on the uphill side. What I mean is, the mortar as a mass is intact but it's as if it has pulled away from the brick to leave a crack there.
    Seems still structurally sound but it's not nice to see. Like a zit on an otherwise nice face.
    Should I slather more mortar onto it or leave it be?
