Tile saw - Forno Bravo Forum: The Wood-Fired Oven Community
Hello,
See more
See less
Tile saw
  • Tile saw
    With all the cutting of FB to be done. I was
    Wondering if y'all could post what saws you
    Use. Or maybe ones to stay away from? Would
    Any wet tile saw work? What are you looking
    For in a saw?
    Re: Tile saw
    I used a Target brick saw that could not have worked any better. I was lucky enough to borrow one from a freind of mine because I think they are pricey.
    Chris
    Link to my photo album:
      Re: Tile saw
      Do I see you using a jig for angles
        Re: Tile saw
        Target is definitely commercial grade...good saw too.
        Old World Stone & Garden
        John Ruskin
          Re: Tile saw
          I used the cheapo 10" Harbor Freight brick saw, mid 200 range and able to do almost all the cuts with a 10". Min 10" saw 14" better, but cost more. Look on Craiglist too. There are several versions of brick jigs out there on the forum, Mr. C has one. Here is pic of mine. They are adjustable to cut a compound cut both taper and bevel at the same time. Do a search for others.
            Re: Tile saw
            I used a Harbor Freight Saw which I bought for about $250 new and hope to sell for at least $150-! They also had a deal on a cheap blade for about $15- which I thought wouldn't last very long - but it did last for about 90% of the entire build (not only the oven but I also used 1,000 bricks in the surrounding structure and cut at least 10% of them)
              Re: Tile saw
              I used a wet tile saw as your first post mentioned; I removed the splash guard, tile guide and the tips of two fingers It wasn't ideal, but it worked.
              Build thread: http://www.fornobravo.com/forum/f6/m...sts-20752.html
