Two questions
  • mleuck
    • May 2009
    • 31
    Two questions
    I am in the planning stages to build my 42" Pompeii oven. First, where/how do I find instructions to make the forms to create the dome(the forms the brick lay on as the dome is built)? Secondly, are their instructions how to make the "indispensible tool"?
    Thank you for the help.
    Michael
  • GianniFocaccia
    • Jun 2009
    • 1645
    Re: Two questions
    Answers to your questions can be found simply by studying pictures of builds here on FB. You are free to copy/borrow/steal any/all designs, procedures, practices you see.
    The rest, like mixing mortar or laying bricks on bond, is trial and error.
    Google 'the indispensable tool' + Forno Bravo to get ideas.
    • wotavidone
      • May 2011
      • 800
      Re: Two questions
      At its simplest, for a straightforward hemispherical dome, the IT is a butt hinge, stick and L bracket.
      Make sure that the bottom edge of the L bracket is no lower than the middle of the internal face of the brick, and, looking along the stick, make sure the hinge pivot point and the bottom of the L bracket are in line.
      This is necessary so that you don't dislodge the brick when you lift the bracket.
      If the L bracket is lower than midway, the bottom of the bracket will push the brick out when you lift the IT.
      • mrchipster
        • Apr 2010
        • 1502
        Re: Two questions
        Also look at this it is a listing of best of the best
        Being new to the Forno Bravo web site, we quickly realized that we wanted to build a pizza oven and access the best information available, but did not know where to look. Getting smart about building a Wood Fired Oven (WFO) would have been easier with a little tutoring. So, listed in bold below, you find a few shortcuts to
        Chip
          • 9215
          Re: Two questions
          http://www.fornobravo.com/forum/8/ne...tml#post167578
          Use the plastic conduit as an arm instead. You simply bend it to remove it, far easier.
          • Akamicko
            • Jul 2014
            • 13
            Re: Two questions
            Michael
            Hi Michael,
            To form my dome I used a simple set-square. The technique can be seen here:
            Just like the indispensible tool, it can be easily adjusted to suit any dome height.
            Good luck with your build !!!
            Micko
            Micko
            My oven build: http://www.youtube.com/watch?v=cpqakvZMhNw
            My dome gauge/indispensible tool thread: http://www.fornobravo.com/forum/f28/...ive-20917.html (Dome Gauge - a simple alternative)
            • jcg31
              • Aug 2007
              • 263
              Re: Two questions
              Good luck with the build!
              • oblertone
                • Apr 2014
                • 93
                Re: Two questions
                Michael
                Michael, I'm certainly no expert but you seem to be confusing two build methods, either of which will enable you to produce a WFO.
                A Form build uses an internal support framework to support the bricks (or castable material) as you build. These forms can be made from wood or even expanded foam sheet; the trick is ensuring you can get them out after completing the dome !
                The indispensable tool is a device anchored in the middle of the oven to ensure each brick is the same distance from the centre point, no forms are required as the IT swivels in use and is used to place each brick in turn.
                Just to confuse matters even further, a pile of sand can be used as a form; and you can build a dome freehand (as I did, see link below), the choice is yours.
                Happy building ... Paul
                Build thread: http://www.fornobravo.com/forum/f6/m...sts-20752.html
