Oven wood storage...
  • Xabia Jim
    • Dec 2006
    • 1168
    Another post made me think about this tip:
    When storing wood under your oven or fireplace, make sure you have an aggressive slope so that any storm water drains away from your wood and avoids any puddling.
  • ballard6449
    • Aug 2007
    • 12
    Re: Oven wood storage...
    XJ, that's good thinking. Too late for me... maybe I can build a "rack" to keep the wood off of the slab.
    To also help, after cooking and the oven has cooled a little I've started pushing coals and embers to one side and put a load of wood on the other and let it "cure" in the heat for the next time I start a fire. That way, at least I have good dry wood to start off.....
    • Xabia Jim
      • Dec 2006
      • 1168
      Mark, if you've got a puddle you can always just tile your wood storage area and make it drain out.
      • Xabia Jim
        • Dec 2006
        • 1168
        My drainage problem was created when i put in the wall supports for my granite countertop. The slab drained well but the walls were perpendicular to the slope. When it storms, I get a puddle backup at each wall (dam).
        Tip #2 Put drain holes at the base of walls, counter supports, etc that run perpendicular to the slope of your terrace/patio.....
