Curing Fire
  • Wayne Paletski
    • Feb 2015
    • 6
    Curing Fire
    I am near the end of what feels like my never ending build. Just need t sort out my chimney which I posted a question about in another thread and then insulate and render.
    I have done a lot of reading about curing fires but can't find a definitive answer onto whether to have a curing fire before or after i insulate and render.
    I would think that maybe I should do a curing fire before I insulate so i dont lock the moisture in.
    Any help or advice would be appreciated.
  • NCMan
    • Jan 2014
    • 846
    Wayne.......that is a long standing debate on here. I dried my oven w/the insulation off, as do some others. That is the way I recommend and will continue to do so w/future ovens. However, there are builders that choose to do it w/the insulation on. Both methods work. The real trick is to go slow and steady w/your drying fires. Don't be in a rush.
    My Build:
    • gastagg
      • May 2013
      • 271
      Wayne, check out this thread...read the whole thing through...it is worth it. I just got done curing and basically followed the approach that emerged over time, which is reflected in the thread.
      George
      See my build thread here.
      See my build album here.
