I'm finally ready to start building my dome, so need to build an IT (unless someone has one they're willing to part with (I'm lazy and busy)). I've found enough designs to get the general idea for how they work but are there any non-obvious things I should be keeping in mind?
Indispensable tool design
Tags: None
There are some really good threads on building of the IT, but the two things that come to my mind are making sure the rod/stick/tube part of the IT connects to the brick locating L bracket at the brick centerline, and understanding how the location of the centers of rotation (around the dome) and pivot (up and down) effects the size and shape of the dome.My build thread
https://community.fornobravo.com/for...h-corner-build -
Thanks! I'll put some more time into research tomorrow. I think that some combination of my idiocy and the subpar search functions on this site keep me from readily finding what I'm looking for most of the time.👍 1Comment
My indispensible tool (a variation on a FB theme) - Forno Bravo Forum: The Wood-Fired Oven CommunityShare your favorite tools, time saving tips, and what you learned while building your oven.
Is the thread where the term was coined (albeit I misspelled indispensable with my first post)Comment
jcg31,
Long time no see, as you can see, your IT thread is still a core baseline used by many builders.Comment
