Recommendation for Cutting Brick
  • CapePizza
    • May 2017
    • 228
    I'm getting my materials together to build a Pompeii style oven. I'm looking for any feedback / information on cutting the firebricks. I saw these saws at HF and wondering if anyone has experience with any of these 3 saws shown. Please see attached photo. Obviously the less expensive one, if it works well, would be my first choice, but not adverse to the $269 model. Any other saw recommendations would be welcome. Thanks very much for the help.
    John
    ______________
  • Chach
    • Mar 2018
    • 635
    I have the older 10" saw i purchased about 8 years ago...A 14" saw would be even better to cut the arch bricks but the 10" works as well you just have to do it in 2 passes. 7" saw is to small in my opinion. I originally purchased my saw for retaining wall project and since have done 2 stone flooring projects and now the pizza oven.
    Ricky
    My Build Pictures
    • shanxk8
      • Nov 2010
      • 201
      I used a 7" saw for my build. It obviously also required 2 cuts, one from each side. After the cuts there was about 1/8 to 1/4" that remained uncut. That was simple enough to break. If I needed a smooth edge I just needed to run the rough remaining bit along the blade (Using like a grinder) to clean up the excess.
      The water tray was quite small so I set it aside and used the saw propped on fire bricks in a Rubbermaid container full of water.
      If I were building ovens often, I'd get a larger saw, but for a one off project, the 7" saw worked fine for me
      David in Calgary
      My Build Thread
      • PearlLord
        Banned
        • Jun 2020
        • 2
        Use the DEWALT 7 in. Concrete and Brick Diamond Circular Saw Blade for dry and wet cutting. This blade is ideal for brick and other masonry materials. It features heavy-duty metal construction and a hard, diamond-reinforced edge for durability.
        text to speech
        mortgage calculator online
