Removing ash from hot oven
  • terdferguson
    • Sep 2013
    • 94
    When you guys cook with residual heat in the following days after making pizza, do you remove all the ash? If so, what do you use to remove the ash from a hot oven? Normally I use a brush but I'm guessing the bristles will melt.
  • Kvanbael
    • Feb 2020
    • 157
    My pizza-oven-toolkit came with all kinds of gadgets such as a scoop, a scraper and a metal-brush-on-a-stick. The brush is somewhat convenient, but you can also use a piece of coper pipe to blow the ashes to the back before scooping them out with your pizza peel.
    The peel is probably the most versatile tool but a pipe is the most under-rated tool. It's also great for reviving a lazy fire.
    Ashes and embers get collected in a metal bucket to let them cool further.
    For pizza and bread you need a perfectly clean floor, so I finish off with a damp cloth wrapped around my pizza peel.
      • 9212
      Probably better not to use the metal brush as there have been incidents of people ingesting a bristle that’s broken off. It can perforate stomach, intestines or bowel. I agree about the blow pipe, but be careful to blow not suck.
      • terdferguson
        • Sep 2013
        • 94
        Thanks guys. I have and use the blow pipe. I didn't know if there was anything else for getting the floor perfectly clean that I hadn't thought of.
        • Ken.thai
          • Sep 2021
          • 39
          This made me laugh
          You give Americans an inch...
          And they'll invent their own metric system..
