Perlite vs Vermiculite. Use one or both?
  • stevef22
    • Mar 2020
    • 131
    Under floor and around dome. What is preferred? Ive seen people use one, or both. Does it matter?
    5:1 ratio around dome 3-5 inches
    8:1 ratio under the oven floor 4-6 inches. Correct?
    What is the difference between these?
    Thank you
    • 5259
    Ratios are just the opposite. See attached. Perlite or Vermiculite what ever is easier to get. David S suggests a mix of the two., Click image for larger version
Name:	Vcrete K values.JPG
    • stevef22
      • Mar 2020
      • 131
      Thanks for clarification UtahBeehiver. Always helful.
        • 5259
        Also, v/pcrete roughly requires twice the thickness of CaSi or ceramic blanket. IE, "minimum" floor/dome thickness of CaSi board/ ceramic blanket (dome) is 2" so you need at least 4".
        • stevef22
          • Mar 2020
          • 131
          Got it, Thank you
