I may have an opportunity to get some salvaged bricks for use in making a wood-fired oven some time in the future. The brick is from a pottery kiln which is fired to 2,000 degrees. Is this the same sort of brick that would be used for a bread oven, and do I have to worry about any contaminents that would make the bricks unsafe for use in baking?
Also, as a kind of two for one question: how many bricks will I need. I know there are a couple of different sized ovens and I'm not sure what I will finally build, so give me a high end estimate.
Thanks for your help.
TJ
TJ
