Infrared thermometer failure
  • diulin
    • Jun 2021
    • 10
    A few days ago, right after changing its 9v battery, my Zoto IR thermometer started reading way below the actual temperature. I know this, because I can point it at my woodstove, and it reads around 155 to 160 degrees Farenheidt. Point it at cooler things and the temperature does go down from there, but I haven't checked to see if there are temperatures at which it is accurate. There's nothing at all wrong with the display, but it is just obviously giving me the wrong temperature (by a lot). Has anyone else had this experience or have any suggestions for fixing it?
    Thanks.
    Have you checked to see if it’s set on C rather than F. It may have switched by default when you changed the battery.
    IR thermometers only read the surface temperature so can be quite misleading. The temperature of the surface will be markedly higher than the centre of the brick or refractory. If shooting a temperature in my oven when it’s really cranking , at the crown my IR gun will usually read ERR meaning it’s beyond its range. Similarly the floor temperature can vary considerably from front to back and from side to side. A far more reliable method is the burning away of the black soot which occurs at around 300C.
    • diulin
      • Jun 2021
      • 10
      Thanks for the suggestions. Yes, my first thought was that it was reading in C, not F. But I checked that. And I've tried various surfaces. I don't have any way of measuring their precise temperature, but I know they are way above what the thermometer is reading. If the display on the thermometer were flickering or there were any other signs decline in its function, I'd figure it was just bad. The fact that it acts like everything is fine is what makes me wonder if it just needs to be reset, recalibrated, or something.
        That is a pity. I have no idea how it is recalibrated, sorry. For thousands of years people have been successfully cooking in wood ovens with no fancy electronic gadgets that always fail sooner or later, but just relying on your own body, the heat on the open palm and eyesight viewing the interior colour. Learning to cook this way provides a link to the past, particularly when combined with harvesting your own wood.
        • Matt BBQ Pros
          • Jan 2026
          • 4
          That usually points to a sensor or emissivity issue, not the display or the battery itself.
          A few things to check before writing it off:
          Battery voltage – Even new 9V batteries can be weak. IR guns are picky. Try a different brand or a fresh lithium if you have one.
          Lens cleanliness – A light film of dust, smoke residue, or condensation on the IR lens will absolutely tank readings. Gently clean it with a microfiber cloth and a bit of alcohol.
          Emissivity setting – Some IR thermometers have adjustable emissivity. If it got bumped or reset during the battery change, it’ll read way low on things like metal stove surfaces.
          Target surface – Shiny or bare metal (like a stove) will read low unless you put a piece of matte tape or flat paint on it and shoot that spot.
          If it’s still reading 150–160°F on a hot woodstove after those checks, the internal sensor is likely failing. Unfortunately, when they go, they usually go that way — consistently low but still responsive.
          Quick sanity test: boil water and shoot the surface of a matte mug right after pouring. You should be close to 212°F. If it’s way off, it’s probably time for a replacement.
          • Zyvion
            • May 2026
            • 4
            Check whether it got reset to the wrong emissivity setting, if your model supports that. If not, it may just need a hard reset or a few minutes with the battery removed.
