A stronger arch
  • toddj
    • Aug 2008
    • 117
    A stronger arch
    This is how I plan to do my dome and chimney arches.
  • Ken524
    • May 2007
    • 1655
    Re: A stronger arch
    Hi Todd,
    I like the way it looks. Will that design reduce the outward pushing forces on the side walls that most of our other arch designs have? Seems like it would.
    Keep up the great work!
    Ken H. - Kentucky
    42" Pompeii
    • toddj
      • Aug 2008
      • 117
      Re: A stronger arch
      Hi Ken,
      I really like the squarish arch like on your oven VS. the round arch but I needed to find a way to make it more of an interlocking structure.
      It should greatly reduce outward force - not eliminate it - but it does push a lot of the force down rather than out.
      anyone want to run the numbers and map the load path????
      • toddj
        • Aug 2008
        • 117
        Re: A stronger arch
        Testing it out with a rough cut.. so far I like it...
        • christo
          • Feb 2006
          • 913
          Re: A stronger arch
          I like the proportions very much.
          How does the base of the arch interlock with the dome ring? Are the bottom 3 or 4 bricks integrated into the opening of dome?
          Christo
          My oven progress -
          sigpic
          • toddj
            • Aug 2008
            • 117
            Re: A stronger arch
            Hi Chrissto, yes this photo does not show the bottom two bricks so it is acutally 5" taller than what is shown.
            • dbhansen
              • Jun 2007
              • 566
              Re: A stronger arch
              Superb work so far, Todd! Let me guess - you're an engineer?
              Picasa web album
              Oven-building thread
              • toddj
                • Aug 2008
                • 117
                Re: A stronger arch
                Ha Ha.. You offend I an an inventor and mad scientist but I do have engineers that work for me...
                • Les
                  • Sep 2005
                  • 2945
                  Re: A stronger arch
                  The strongest arch that can be achieved is a true semi circle. Is it needed in our apps - no. I think what you have going looks great and you should have no problems. I am assuming that I need to put around 200 pounds of brick, mortar, flue pipe on top of mine. That is why I added some more steel. If you are going to load any arch - I would plan on some support. Fire brick, being solid, doesn't offer near as much in shear strength as core's do.
                  Great work Dude, like I said , make us proud. I KNOW you can do it.
                  Les...
                  • toddj
                    • Aug 2008
                    • 117
                    Re: A stronger arch
                    THanks Les!!
                    • toddj
                      • Aug 2008
                      • 117
                      Re: A stronger arch
                      well its in and im waiting for it to set up..
