Board System
  • mfiore
    • Oct 2007
    • 919
    Board System
    For those that have utilized the Board System (as described by Les), how does this work as you close in on the top of the dome? Does the board get wedged in? How do you get it out at the end?
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
  • Les
    • Sep 2005
    • 2945
    Re: Board System
    Mike,
    I had to notch the board with every course. If you are off 1/32 of an inch it will hang on the next one. I quit using it when I got to course 8 or 9 (don't recall). The opening was small enough at that point, and above the entry, I was able to just eye ball it. I was using hot melt glue to hold the bricks, made it pretty easy to get a good alignment. The BS worked for me - but not all the way to the plug.
    Les...
      Re: Board System
      Hey! There you go! Why mess with mortar?
      • Les
        • Sep 2005
        • 2945
        Re: Board System
        I thought it was brilliant - it's made of wax and pretty much evaporated before it hit the floor. And ANYTHING to keep me from having to crawl inside the mouth of "Diablo's Den", to do clean up, works for me.
        Les...
        • mfiore
          • Oct 2007
          • 919
          Re: Board System
          Sorry, Les. I thought you were joking. Could you clarify how you used a hot glue gun to hold the bricks together?
          Mike - Saginaw, MI
          Picasa Web Album
          • Les
            • Sep 2005
            • 2945
            Re: Board System
            Mike,
            I put a little at the front then sat in the shim. The next brick I would put a little in front and some on the side of the previous brick, adding the shim. I just kept doing this until it was time to mortar. Don't know if you were following my build, but I am a huge believer in the grout bag. The only down side to this process was that the brick's need to be dry for the hot melt to hold. Turned it into a very slow task.
            Les...
            • Frances
              • Aug 2007
              • 2186
              Re: Board System
              HaHA! I knew it!
              ...well, I knew you were using something we didn't know about, my guess was magic, so I think I got pretty close...
