Chipped brick
  • Chipped brick
    During my oven build,I noticed a brick with a chip about 1/2 " in diameter. should I remove the brick? repair It? and if so ,how?
    Thanks!
    Re: Chipped brick
    masuzzu
    I wouldn't worry about it...especially not if it is in the slightest way inconvenient...it won't affect the oven's performance...incidentally where in CT...I used to wrok in SE CT...Norwich actually...lived in Willimantic
    Best
    Dutch
      Re: Chipped brick
      Thanks for the information,
      I live in the opposite end of Connecticut , near the New York border.
        Re: Chipped brick
        I know that area pretty well also...I grew up in the hudson valley in NY...dad worked in Greenwich...good friends in Fairfield County...good luck to you! I will enjoy seeing your oven progress!
        Best
        Dutch
