Insulation Options??
  • Xabia Jim
    • Dec 2006
    • 1168
    James, there should probably be a sticky on insulation....one of the most important elements of any WFO!
    What insulation material (s) do you use for your oven?
    49
    I used only one type of insulation material for my oven
    2.04%
    1
    a High-Tech Ceramic Fiber Blanket
    26.53%
    13
    Other Insulation Blanket materials
    8.16%
    4
    a High-Tech Insulation Board
    20.41%
    10
    Other Insulation Board materials
    4.08%
    2
    Insulating Firebricks
    4.08%
    2
    Other Masonry Type Insulators
    4.08%
    2
    A homemade Perlite/Vermiculite mixture
    26.53%
    13
    Something else?....let us know!
    4.08%
    2
    No Insulation, but I do get to cut a lot of wood!
    0.00%
    0
  • Xabia Jim
    • Dec 2006
    • 1168
    Re: Insulation Options??
    I used a commercial masonry insulator called Argilite
    .....an expanded clay ball that floats
    ..what I could find locally
    • Frances
      • Aug 2007
      • 2186
      I used Vermcrete under the floor, and Rockwool (that'd be "Other Insulation Blanket materials", right?) and loose Vermiculite on the dome.
      Couple of people have done that recently. And its pretty standard for house style ovens, isn't it?
      • Dutchoven
        • Apr 2007
        • 931
        We used combinations...vermicrete and then FB board under the oven...then FB blanket...fiberglass and loose vermiculite on the dome
        Best
        Dutch
        • SteveP
          • Oct 2008
          • 120
          I used ceramic insulation board under the oven, 2-4 inches of spun ceramic blanket then 4 inches of perlite/portland cement mix. Works great.
          My WFO project: http://picasaweb.google.com/stevprin/WFOSmallPhotos#
          • ERASMO
            • Oct 2008
            • 85
            Steve
            I looked at your pics. Looks Great!!-- What did you have 2" FB board under the floor and the 2-4 inches of spun blanket and the 4" perlite/portland mix on top?
            • SteveP
              • Oct 2008
              • 120
              Frono Bravo was out of stock on the FB board so I found a ceramic insulation board on-line and used it. My oven is 40 inches and I used 3 pieces of 2ft x 3ft board. I got 50 sq ft of the 2" spun insulation blanket (it comes in 1, 2 and 3 inch thicknesses) from the same website. Then used 16 cuft of perlite with some portland cement. I got the perlite from a nursery wholesaler down the road from me. Anyway, when the oven floor temp is around 800F, the bottom of the hearth slab is only about 100F. The exterior of the perlite/cement layer and the exterior of my housing is at ambient temperature. I am very happy with the insulation so far.
