sealing exposed fire bricks?
  • Jochen
    • Aug 2008
    • 25
    Last night we had very heavy rain showers over the south of England. This morning I noticed that the firebricks on the outside arch and chimney were very dark because they soaked up a lot of water.
    My question is whether it is worth protecting the bricks? B&Q sells a product with the following description:
    "B&Q Brick and Masonry Sealer is a water repellent that penetrates the surface of dry porous brick, stonework and concrete. Once applied it forms a protective barrier which helps prevent damage from the ingress of water and damp whilst allowing the surface to breathe and let moisture vapour escape."
    I guess that one issue with using a product like this is that the chimney is getting very hot.
    Any advice or thoughts would be much appreciated.
    Re: sealing exposed fire bricks?
    I wouldn't put any chemical sealer on brick that gets hot.
    A) It will destroy the sealant.
    B) It will outgas all sorts of nasty chemicals when you're cooking.
    • Rastys
      • Feb 2009
      • 118
      Jochen,
      can I ask you why don't you provide some basic shelter for your oven.
      Not being aware of your build or surrounds, I am not aware of yours as a dome or housed oven.
      To make your oven more useable, I would incorporate some type of extra shelter in the form of a wider roof, pergola or even the commencement of an outdoor kitchen. My oven was only the start of greater and yes, more expensive additions, but you will appreciate them and use them all together.
      Rastys.
      If you don't succeed the first time, try again and again until you get it right!
      • Nev Grady
        • Feb 2009
        • 24
        Is it possible to cover the exposed bricks with waterproof render or even tile it with mosaics or even larger tiles? I'm just building my oven and plan to use hard housebricks for the outer oven opening and arch for this very reason. There should be no exposed firebricks at all. Where I live in the north of England we get much more rain than you lot in the south!
        • Jochen
          • Aug 2008
          • 25
          I have thought about building a pergola over the oven and have a nice covered area around the oven. Adding an additional layer of render could be an option as well but I do like the current design and covering the bricks up would make the oven look very different. Attached is picture of the oven.
          I agree with dmun that a sealer is not a good idea because of the fumes. If I am not building a shelter this year I will definitely cover the oven during the winter.
          Does everyone know whether the bricks could be damaged by the rain in the summer?
          • gianlucaf
            • Oct 2019
            • 27
            About an update here ? I have same dilemma , thinking about building exterior door and use a hit temp gasket and latches to make it snug and watertight .
              This is a really old thread. There are some more recent threads on the same subject.
              I don't understand the need for heat resistant gaskets for an "exterior" or what I call a storm door . My storm door is made of wood and sets in a reveal formed by the face brick. I have a good insulated door to seal the heat inside the oven. That protects the wood storm door.
              A reveal or recess for the storm door helps a lot to protect from water intrusion. Some of the premade igloo style ovens we see on the market address this with a brow over the entry. Slightly lowering and or tilting the entry shelf to shed water away from the entry helps also.
              • JacksonC23
                • Jan 2020
                • 3
                The sealer is a bad idea, honestly, better build that pergola for it, it's a much smarter and safer option.
