Hello!
I had one of those "duh!" moments today that I wanted to share, a more efficient alternative to cutting all the bricks in half first.
As suggested by others here, I'm using the "Angleizer" to great success, and I realized that by starting with a whole brick, it's possible to cut two trapezoids with just three passes through the saw vs. five using the half-brick method....a HUGE timesaver and less wear on those expensive saw blades.
I set the Angleizer tool and mark one trapezoid, then turn the tool 180 degrees and mark the second trapezoid with a scant 1/8" between the two parallell lines, aka the width of the saw blade. Then, one cut on each side plus one cut to divide the two trapezoids, and voila!
Here's what a marked full brick looks like:
happy sawing!
happy sawing!
