Brick and Block cutter
  • KINGRIUS
    • Aug 2009
    • 113
    I would really like a wet saw for my oven project but I just cant afford one right now. I have a skil saw w/mason diamond blade already, but I was wondering if anyone has had experience with a brick cutter such as this one: - Harbor Freight Tools - Quality Tools at the Lowest Prices
    It seems like it would be difficult to get accurate cuts with, but for that price I'm willing to learn how to use it with some success.
  • shuboyje
    • May 2009
    • 406
    Re: Brick and Block cutter
    I bought one when I was planning to make my oven out of half bricks figuring it would be a good fast easy way to chop them in half and then just use the factory side on the inside. For that purpose it would work well, but the cut it makes is VERY rough, nothing you could use for a finished surface no matter how much you plan to chip away at it. Since I ended up using 1/3 bricks for my oven, it went un-used.
    • KINGRIUS
      • Aug 2009
      • 113
      This one from harbor freight says you can cut angles with it. I think I'll try it. I've got plenty of crapy used bricks to practice on. If I can't get any good with it I'll just have to use the skil saw.
      • shuboyje
        • May 2009
        • 406
        I should have been more specific. I have that exact one from harbor freight.
        • KINGRIUS
          • Aug 2009
          • 113
          I see. Well now we both do!
          • skemcis
            • Aug 2008
            • 34
            Check out Lars posts. I believe all of his bricks were cut by hand.
            • KINGRIUS
              • Aug 2009
              • 113
              Ok, I'll check them out now. So far that tool really sucks though. You weren't kidding about "rough". OUCH!
                Don't feel bad, using a brick set is a super-skill, like cutting glass. I've never been able to avoid making a mess of either one.
                Think of all the stress you'll be saving your muscles and tendons.
                • KINGRIUS
                  • Aug 2009
                  • 113
                  I guess thats assuming I don't use the tool? Yes I already have enough aches and pains, I don't need another excuse for some more. I will probly stick with my handy skil saw. I've done a fair share of brick cutting already and it's still working. For now...
                    As in all dry masonry cutting, protect your lungs. That dust is not good for you.
                    • KINGRIUS
                      • Aug 2009
                      • 113
                      Thanks, I will.
                      • goodgulf
                        • May 2009
                        • 4
                        Here is a video using a similar tool from another manufacturer.
                        YouTube - blockcut1's Channel
                        There are 2 other videos on you tube by the same poster cutting other types of brick.
                        • KINGRIUS
                          • Aug 2009
                          • 113
                          Thanks for the link! It was really helpful. I'm going to practice some more with it now.
