Re: Diamond Blade Question
The answer to that question is that it depends on if the blade is a wet cut only or a dry blade. The manufacturer will specify which type. Generally, you can wet cut with a dry blade, but you should not dry cut with a wet blade.
Wet cutting power tools are electrically insulated.....if you wet cut with a tool designed for dry cutting, you are risking electrical shock.
