Diamond Blade Question
  • #31
    Re: Diamond Blade Question
    Originally posted by George_M View Post
    Hi,
    I bought a masonry diamond blade for angle grinder.
    I read that need water while cutting bricks,but can i use water when i use an angle grinder or only saws need water?
    The answer to that question is that it depends on if the blade is a wet cut only or a dry blade. The manufacturer will specify which type. Generally, you can wet cut with a dry blade, but you should not dry cut with a wet blade.
    Wet cutting power tools are electrically insulated.....if you wet cut with a tool designed for dry cutting, you are risking electrical shock.
    Old World Stone & Garden
    John Ruskin
    • #32
      No,the blade is for dry cutting.Ok i will not use water.
      Thanks!
      • #33
        Is your saw ok to cut using water? If it is I would use water. This will prolong the life of the blade. Plus you will eliminate the dust. You could also use a gfic cord for extra electrical protection.
        • #34
          No,it's not waterproof.I don't want to risk.
          I will cut the bricks without water.
