I am quite torn on chimney design. I had purchased what I thought was an 8" interior (10" exterior) double-walled pipe (Duratech I assume) in two two foot sections locked and caulked together into a four foot pipe. My intention had been to take it apart and use one section. Upon cleaning the caulk I determined that it is a single four foot pipe, which will look absolutely ridiculous on my current design and will represent a significant wind-hazard without proper support.
I am also considering building my chimney out of flue tiles or out of fire brick...which leads to my question. If I build a chimney out of full bricks, about four bricks per layer, edge-on (4.5" high), then I need about six layers to get a two foot chimney, or about 24 bricks, which is around 175 lbs. Would an entry arch with a big hole in the top (the vent) support that kind of weight? I'm trying to picture myself standing on my vent (I'm about 160) and standing there forever, not just a minute. I don't know if my entry arch would support that kind of weight for years...or maybe it would, I don't know.
Related question, if I built a chimney out of splits on edge (4.5" tall but only 1.25" thick) would that stand up six layers without being at risk of collapse? It seems like a rather thin wall for such a height. How might that be accomplished, or are thick walls necessary a two foot tower?
Finally, on a related topic, although unspecified in the thread subject, if I go with flue tiles, I could build a brick facade around it with much lighter bricks, but only if nonfire bricks could be used in such an application. Since the clay flue is totally uninsulated, a lot of heat will hit the facade bricks, even after I leave a 1/2" gap for expansion and general adaptiveness...so the question here is: COULD nonfirebricks be used to facade clay flue liners at all, or must it be fire bricks to bear the heat?
To sum up:
Sorry for the long post.
To sum up:
- Will a Pompeii-style (or see the arch pics in my build thread) vent-and-arch support 175 lbs (call it 200 once a cap is in place)?
- Can a clay-clue chimney be facaded with nonfirebricks considering the heat that will certainly transmit through the clay and the gap to the facade?
