I know most people use steel studs, but let's assume for the moment that I build my enclosure out of rebar instead. Just bear with me. How might I attach hardibacker to it?
I was thinking that I could use those brackets which hold small pipes in place. I don't know what they're called: a small flat strip of metal bent so as to wrap 180 degrees around a pipe, then bent 90 degrees out to the sides to make a flap with screw holes in each flap (lower-left in the linked image below):
If I could find those in the right size for the rebar (I assume HD has them), I could use it to attach to the hardibacker...but how? I assume I can't just drive a screw in. The hardibacker isn't thick enough. I'm afraid that a screw would rip out. Do people agree with this concern or would very short screws (1/2") work?
Alternatively, I could drill holes through the hardibacker (what kind of drill bit do I need?) and attach the same brackets with nuts, washers, and bolts instead. I would have to figure out how to deal with the protruding bolt head when I surface the hardibacker, either with stucco or stone. Does it sound feasible that bolt heads could be dealt with when surfacing or would they represent a a serious problem with this design?
Thanks.
Thanks.
