G'day
Using an iPhone 1 pic per post
Pic of the back of the external door. It has an alumimium rim which fits into the entrance and stops anything that blows around it. The bottom is a piece of hardwood attached at a slight angle. Thus the weight of the hardwood plus a firebrick effectively keeps the door up against the brick without the need for hindges or catches to be drilled into the brickwork.
This is still mk 1 and works well enough and is not to ugly so I havnt changed it.
The black mark on the face of the door in the previous post is flying fox poo. They're a large fruit eating bat, so the poos highly acidic. It will strip the paint off you car if you leave it same with the dome paint. So the domes got the added advantage off being flying fox poo proof.
