Re: Karangi Dude's 48inch Oven
Hi Doug
Just curious if you could explain this further. Went back to the start of your build and couldn't find it mentioned. I get the inverted V discussions just need some further explanation of your method.
Another question also. Am i right in saying your outer landing on your build is one standard brick long [230mm] plus half brick decorative arch at the front?
Cheers Colin
				"You can see how Josh is following my lead on only cutting one side of each brick to avoid the upside-down vee's it is working well."
Cheers Colin
 . Also with a 16" blade you will have more than enough cutting depth for anything you will come across in your build. Good luck and take plenty of pics to document your build.
