new build in werribee
  • Hi All
    Just checking in.
    Oven is pretty much on hold as I have had to begin construction on our Verandah and Deck. As my partner son's landscaping team have completed all the holes for the verandah posts and deck stumps. I have managed to get these concreted and all jbearers and oists installed for the deck. This weekend managed to get 6 posts installed with 2 left to install.
    Oven base completed and I'm up to the hearth but alas I have no room to set up the brick saw.
    Will post photos soon.
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
    • Click image for larger version
ID:	434890 Click image for larger version
ID:	434891 Click image for larger version
ID:	434892 Click image for larger version
ID:	434893 Click image for larger version
ID:	434894 Click image for larger version
ID:	434895 here are some photos of progress
      Cheers Colin
      Oven 1 Completed
      • and some more. had to stop oven and begin verandah deck construction
ID:	434901 Click image for larger version
ID:	434902 Click image for larger version
ID:	434897 Click image for larger version
ID:	434898 Click image for larger version
ID:	434899 Click image for larger version
        Cheers Colin
        Oven 1 Completed
        • And the Verandah and Deck continues
          .Click image for larger version  Name:	IMG_20201213_191932.jpg Views:	0 Size:	675.2 KB ID:	434904 Click image for larger version  Name:	IMG_20201213_191854.jpg Views:	0 Size:	706.3 KB ID:	434905 Click image for larger version  Name:	IMG_20210114_095540.jpg Views:	0 Size:	37.4 KB ID:	434906 Click image for larger version  Name:	IMG_20210114_095553.jpg Views:	0 Size:	114.7 KB ID:	434907 Click image for larger version  Name:	IMG_20210114_095559.jpg Views:	0 Size:	105.3 KB ID:	434908
          Cheers Colin
          Oven 1 Completed
          • Have been a bit scarce but ver busy. Have my Verandah frame completed and approved now.
            I will post some photos shortly.
            Cheers Colin
            Oven 1 Completed
            • G’day Colin
              you might want to check out “the other oven types section” v12spirit has made a welcome appearance and made mention of yourself
              regards Dave
              • HI All sorry i gave been scarce has been a busy time since last post am now a grandfather have been busy trying to get verandah done and dusted before March deadline [will fail] due to material delays and tradesman delays wont succeed.
                I am getting verandah rendered currently and have ordered roof.
                Then onto paving after that I can start oven. Yay.
                ​​​​​​​Will post photos when a get a chance.
                In interim have mastered pizza in my inside oven [not the same but close]
                Cheers Colin
                Oven 1 Completed
                • https://community.fornobravo.com/cor...EAAAICRAEAOw==​​ Finished Verandah in April, the open louvre roof is a great addition, now onto Garden, paving and then finally the Oven. Louvre glass panel being built for left side.
                  Click image for larger version  Name:	IMG_20220325_142811.jpg Views:	0 Size:	1.00 MB ID:	448971
                  Cheers Colin
                  Oven 1 Completed
                  • Hey Collin,
                    Turned out very nice. As always nice attention to detail so looking forward to seeing number two oven.
                    • Question for anyone.
                      I used to be able to edit previous posts. Now although i am signed in I can only edit a new post but NOT any previous post. I cannot see any setting anywhere that allows me to adjust this. I need to be able to edit previous posts eg Post 1.
                      Any clues?
                      Cheers Colin
                      Oven 1 Completed
                      • Hi Colin,
                        Any Member Moderator that you feel comfortable with can work with you to edit an older post. Some months ago we noticed spammers going back after a few weeks and editing their (seemingly legit) original posts to include CRAP links. Most forums have a time frame for which posts can be edited. They range from 30 minutes to 24 hours. At that time, I asked Forno Bravo to consider a time frame. I don't know what that time frame is or when it was applied. I'm guessing it was done on the last upgrade. It's BS that we have to do this but, there is SCUM out there that want to make money off of free forums such as ours.
                        Anyways,
                        Send a private message to me or to any of the other Member Moderators on what changes you want made .
                        • Hi gulf that does not help me, although it explains what is happening, so thank you. If you look at my post #1, I have set up an index to the thread and to keep things happening I need to be able to edit that Post.
                          It is painful to have to ask Utah beehiver to make any changes as he has his own things to do. On one of my last posts I needed to make a change to it. Seemed to be locked out within 48 hours. Feeling that maybe a week is a better time frame or even a month. Or
                          Why can't it be setup that only the post owner can make changes? I worked in IT and know this is possible......
                          On the other hand maybe I should be more careful, so my bad . I did find adding photos seemed different than previous posts hence the problem i had.
                          Just seems a little messy the way impementation has happened, not withstanding the SCUM [as you said] that have nothing better to do. Shame they cannot use their talents for good.
                          Cheers Colin
                          Oven 1 Completed
                          • Hi All
                            thought i would provide an update.
                            The backyard has been a long haul but is so near to completion. Lots of little things to do still, but very close, louvre roof, electronic blinds paving all done, still need to fill the paving. but managed to get the oven hearth cut and installed. . this is sitting on 75mm Hebel base, 75mm insulation tiles and 25 mm calsil.
                            Need to get some extra fire bricks standard size to get first 2 rows done and some narrow arch bricks to drop dome height. yes using flatter Dome again.
                            Cheers Colin
                            Oven 1 Completed
                            • Hey Collin,
                              Long time no see. Glad you are still working of oven number 2. Be sure to keep us in the loop.
                              • Yes Russel just so busy work, finishing back yard around the oven. But can now fit it in here and there. Nice to hear from you, how is family. Mine now live QLD Daughter and 2 Grand kids now, and Son is in london training as a paramedic.
                                Some photos
                                Click image for larger version  Name:	PXL_20240126_034341215.jpg Views:	0 Size:	1,004.2 KB ID:	457096 Click image for larger version  Name:	PXL_20240126_004612272.jpg Views:	0 Size:	1.30 MB ID:	457097 Click image for larger version  Name:	PXL_20240126_054908134.jpg Views:	0 Size:	1.00 MB ID:	457098
                                Cheers Colin
                                Oven 1 Completed
