Below very bottom of this post was my first ever post. Throughout my WFO build the thread got quite large. My aim with this build was to document it thoroughly with detailed and copious numbers of photos. To make it easier I have included an index to assist those viewing this thread. Please browse around the direct links as there may be photo's on pages either side.
Oven Mark 2
Beginning of New Build in Point Cook Post 1121
The site Post 1121
Base Construction Post 1135
Finishing the Base Post 1141
Build Index for Oven 1
Build Site and IT post5
Base Slab Construction post 24
Base Slab Construction post 32/33
Hebel Block and Panel Base Stand and Build Templates and working out position post 41/42/43/46
Cutting and laying Calsil, Hearth Bricks and First Course post 55
Dome finish examples Post 74
Arch Template, Entry Arch IT Base and Entry Arch Brick Combination Post 77
Hebel panel supports Post 99
Brick Saw Compound Mitre Brick Tray 1 post 107/108, Brick Saw Compound Mitre Brick Tray 2 post 131/134/145, Brick Saw Compound Mitre Brick Tray 3 post 145
Cutting the hearth Post 151/155 , Post 175
Setting up Calsil, Hearth on Base, Dome arch Brick Order Post 184 , Post 191 , Post 194
Setting up arch, IT, Dome templates Post 206/207 First course started Post 212, Hearth First Course completed Post 229
Dome and Entry Arch Construction to Course 6 Post 237, Post 241, Post 256/257, Post 280/281, Post 287,Post 312/314,Post 318/319,Post 324/327/328
Transition courses 6 to 8 Post 350/351/352, Post 362/363/374/375, Post 380/381/383, Post 392/399/400,Post 407
Working out Flared Arch and Landing and Completing Landing Post 432/433/434/435
Completion of Dome Course 8 and beyond Post 453/454/458/459/464,
Couses before plug Post 470/471/472/477/479, Post 496,
Nearly plugged up adjustable IT a plus Post 505,
Last course finished Post 544/545,
Post 610
__________________________________________________ ___________________________________________
Hi all.
After researching this site for most of this year, since my son suggested I build an oven, I have pretty much decided to proceed with the build. So much so that I got out my circular saw measured the area to cut out in my deck and proceeded to cut it out. Engineering of the slab will be tricky as I have 2 bearers 1170 apart. I cannot cut these out so have to construct a 1250 * 1400 slab cantilevered over the bearers and deck to get the width.
I have a friend that is a fitter and turner who has fabricated an IT and I have acquired a brick saw (brand new 16") for $200 but without a brick tray. Same friend is going to fabricate one for me hopefully a compound mitre tray.
I wish to thank benguilford for the advice he has provided so far with a couple of calls I have made. Also to the rest of you that have provided all the valuable information you have on this site. I will post some photos and build ideas soon. Planning a 1metre oven dome, in a Japanese style garden.
Oven Mark 2
The site Post 1121
Post 610
Hi all.
