new build in werribee
  • oasiscdm
    • Jan 2012
    • 1239
    #106
    Re: new build in werribee
    Hi David
    Some of those things were discussed. Lol
    But alas they are empty. Sealed but empty. Couldn't think of anybody I wanted knocked off. Why would I hide a briefcase full of money in there wouldn't I spend it doing gold filigree finish on the oven. Now that would be a sight for an WFO.
    Cheers Colin
    Oven 1 Completed
    Oven 1 and surrounds
    • oasiscdm
      • Jan 2012
      • 1239
      #107
      Hi all
      Quick question. Should i seal the Hebel panel hearth before i lay the calsil board over it, if so with what?
      I will do what Doug [karangi dude] has done with the Barrel oven he is using Hebel with - using hebel adhesive to lay the calsil to the Hebel.
      Can anyone that knows anything about Hebel see anything wrong with this thinking.....I am asking this based on the Wet Floor thread.
      Cheers Colin
      Oven 1 Completed
      • OzOvenBuilder
        • Oct 2011
        • 79
        #108
        Originally posted by oasiscdm
        Hi David
        Couldn't think of anybody I wanted knocked off...
        I reckon Julia Gillard would squeeze in there...you could probably force Abbott's pin head in there somewhere too!
        Boom Shanker! (Neil - The Young Ones)
        • oasiscdm
          • Jan 2012
          • 1239
          #109
          Hi ozovenbuilder
          Not sure about Gillard fitting [my local member btw] hasn't she got a big arse. If the media over the next few days mentions abott and gillard are missing. Well you know where they are. Ssssshhhhhhhhhh dont tell anyone.
          Cheers Colin
          Oven 1 Completed
          • oasiscdm
            • Jan 2012
            • 1239
            #110
            Hi Allan [Brickie in oz]
            Thanks for today unloaded and stacked and by the way loved your oven and advice. Great entertaining area. That is one mighty good looking build.
            Cheers Colin
            Oven 1 Completed
            • oasiscdm
              • Jan 2012
              • 1239
              #111
              Hi all
              Well i have my fingers crossed that i get my Brick Saw back tomorrow. With the winged and mitred Brick Tray. Then i can start doing what needs to be done to get this thing started and finished.
              Yiiiiiiipppppppppeeeeeeeeeeeeee
              Cheers Colin
              Oven 1 Completed
              • oasiscdm
                • Jan 2012
                • 1239
                #112
                Hi All
                Well my bricksaw was returned today with a Brick Saw tray [purchased new 16" for $200 but without the tray retailed for $1600 partners Son got it from major tool auction he had about 6 brick saws, compactors etc. sold the lot except this one].
                I have posted some photos for you of the Tray my mate made for me [Based on Utahbeehiver (Russell) modifications which were based on various other members ideas, thanks to all].
                It needs some modifications but I will give it a go shortly try to find some rubber to stick on it.
                I ordered a 16" saw blade for $90 online, hopefully it will work ok on fire bricks [thought nothing ventured nothing gained for 90 bucks].
                Cheers Colin
                Oven 1 Completed
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #113
                  And one more. I am quite impressed with what he has done. Once the Saw was put back on stand it highlighted a few problems but not insurmountable. Its adjustment range is, well, way more than needed.
                  Major challenge is it should have had a wider gap around the saw blade area for angled and mitred cuts as a Brick corner knocks/tends to hit the other edge on severe mitred and bevelled angle. Might just have to take a couple of cuts at it but that is ok.
                  I'm guessing the angles wont be that dramatic..
                  Any idea how i might attach a rubber mat to the tray so bricks dont slip and will tolerate water????
                  Cheers Colin
                  Oven 1 Completed
                    • 2848
                    #114
                    Gudday Colin
                    Why not try some of that rubber grip mat , I don't know it's name but it looks like a rubber netting. I've a piece I use to hold things that are to thin for a vice on my bench to sand and plane. The holes should hold the water and brick slurry I'd imagine, stuffs cheap and available. Check out the flooring section at bunnings I think it's also used under rugs to stop them slipping on polished floors
                    • oasiscdm
                      • Jan 2012
                      • 1239
                      #115
                      Hi dave
                      Good to hear from you.
                      I will go down to Bunnies tomorrow and check it out. I know the stuff you mean but I was hoping to glue something to the table and stops so that there attached and not loose [saftey and all that].
                      Hit a snag earlier this evening [or i thought i did]. I couldn't get enough height/tilt on the left hand side of the blade because of the mechanism.
                      But had a full brick on the table. Deeerrrrrrrr i will be using half bricks once cut. Now not a problem can go all the way to 45 deg and beyond.
                      Cheers Colin
                      Oven 1 Completed
                        • 2848
                        #116
                        Gudday
                        I was reluctant to mention where I had used this stuff before.
                        It was in the navy. We called it "drape ". It was used to drape over the meal tables. Didn't matter if things were spilt on it .. It continued to grip your plate.
                        Wash it out and even wet it would work. That's why I thought this would work for you , full of water and brick slurry a quick clean and your away.
                        No I didn't get the piece I have from the navy.
                        • oasiscdm
                          • Jan 2012
                          • 1239
                          #117
                          Hi again Dave,
                          Actually found some I already had. Will try it out in the morning.
                          Cheers Colin
                          Oven 1 Completed
                            • 5260
                            #118
                            That is one serious jig on steriods. Looks like it will do the trick. I did notice a slotted blade pic 0479 that should work fine on your fire bricks. I actually preferred slotted over continous rim. I see you had some questions on taper and bevel angles. I rarely used top and bottom cuts, only used them when I mulked up near the dome and inner arch transition. Yell if you have questions
                            • brickie in oz
                              • 3445
                              #119
                              You need to cut that front handle off, when the blade grabs a brick it will drag the table and your hand through the blade, zing.......
                              Without the handle you wont be tempted to hold the front.
                              • Laurentius
                                • Nov 2010
                                • 923
                                #120
                                that is one serious jig on steriods. Looks like it willdo the trick. I did notice a slotted blade pic 0479 that shuld work fine on your fire bricks. I actually prefered slotted over continous rim. I ee you had some questions on taper and bevel angles. I rarely used top and bottom cuts, only used them wheni mulked up near the dome and inner arch transition. Yell if you have questions.
                                Hi Utah,
                                Did you receive my email yesterday? If not check your messages.
