Re: Camo's new 36" build Brisbane
Thanks for the great advice Dave- Yes I am chaffing at the bit to get going but have been working on the "indespensibe tool" and cutting a bit of ply to protect the fire bricks on the floor Got these pieces for the "indespensibe tool" from the local hardware store for about $14 and think they will do the job. Just have to get an angle iron piece welded on the end. Works out the height of the dome will be approx 485mm instead of 450 but I think I can shorten it in a bit as I get to the top of the dome.
Anyway slowly slowly, should start to cut the floor this weekend and then if time, lay a few bricks. Should be interesting as this is the first time at bricklaying although I've layed a few slabs in my time.
Camo
Camo
), this worked out to give a consistent mix and was quick. This was sufficient mortar for say 10 -12 bricks on lower courses, and probably 6 or so in higher courses as the angles increased. I did not shape the brick top or bottom.
