house brick for stand, quick quetsion
  • stonecutter
    • Jun 2007
    • 2003
    #166
    Re: house brick for stand, quick quetsion
    I am positive the cracks are not heat related, so you don't have to stop your curing schedule.
    I would wait to do any exterior finishes ( stucco,brick...anything) before you get an idea how the slab will behave. Again, from your previous pictures, I feel that the strength of the slab is not compromised...but I am not there either. At the worst case scenario, you may have to shore the slab.
    For now, don't worry too much and just keep an eye on it. The crack in your insulation will allow water penetration, so try and keep the whole thing dry as possible.
    Old World Stone & Garden
    John Ruskin
    • stonecutter
      • Jun 2007
      • 2003
      #167
      For anybody that may be reading this...a membrane (plastic sheeting) will stop slab cracking from migrating up into your cladding and/or dome.
      Croc, too late for that on yours, unless you plan on overlaying the exposed slab with something.
      John Ruskin
      • CrocAu
        • Apr 2013
        • 164
        #168
        I seriously doubt the floor got got enough to effect the slab.
        Do you see any cracks running up the mortar joints in your brickwork?
        in the stand brickwork yes, dome doesn't seem to be affected as far i can see inside.
        at the back where the biggest crack is (0.5mm), it travels up in to perlite render as shown on photo but also it travels down 3 bricks and stops about half way in the middle of 4th brick.
        the ones on the left and right that would be no more then 0.2mm don't cut in to brick work in my stand
        • CrocAu
          • Apr 2013
          • 164
          #169
          yes i do plan to put something down to cover the slab now, wasn't before
          most likely i will put tiles of some sort on top and the sides of the slab
          • CrocAu
            • Apr 2013
            • 164
            #170
            just to double check in regards to your comment at the very start of this post
            I noticed just before that temperature was just over 65C on the bottom side of the structural slab some time after fire stopped, when i mentioned 45C before it was with mid-large fire going and I was expecting this to be the peak but it seem heat was moving slowly that way with whole slab acting as heatsink and got hotter from embers after longer period of time when i didn't even consider checking temperatures so yesterday could have been bit higher as well later on during the day after main fire died down but there was lots of embers inside.
            • stonecutter
              • Jun 2007
              • 2003
              #171
              I recommend an exterior uncoupling layer, which will prevent any cracks from migrating through your tile and grout.
              John Ruskin
              • stonecutter
                • Jun 2007
                • 2003
                #172
                That is not enough to crack a slab like that.
                John Ruskin
                • stonecutter
                  • Jun 2007
                  • 2003
                  #173
                  I feel that you need to add some braces to the bottom of your slab to relieve some of the load weight off the walls.
                  John Ruskin
                  • CrocAu
                    • Apr 2013
                    • 164
                    #174
                    oh crap
                    can you please expand on what you have in mind and why so i understand what i'm looking at and how i go about adding the braces?
                    • stonecutter
                      • Jun 2007
                      • 2003
                      #175
                      DON'T PANIC...It's not a big deal. It's also possible that the cracking is caused by the concrete shrinking, and since it's tied into the walls, you get some cracking there too. But over the internet diagnosis usually lends itself to precautionary techniques.
                      Brace the underside of of the slab just as you would for the pour, except use angle iron or sistered PT lumber like a floor joist. For the braces you can use adjustable lally columns.
                      Again this is all precautionary...you should wait and see what happens over a few weeks.
                      John Ruskin
                      • CrocAu
                        • Apr 2013
                        • 164
                        #176
                        i'm looking at my early photos in this thread with stand before the slab and wondering how the hell i got here, even with the support wall in the middle and each corner and middle of the back having tied in 2nd wall of bricks, also concrete was 32mpa and 110mm thick plus a lot of rebar i'm looking at serious problems?
                        i'm starting to wish i never ventured down the path of build WFO
                        • CrocAu
                          • Apr 2013
                          • 164
                          #177
                          btw stonecutter, i really appreciate your help and all the info (same goes for everyone else posting before) and hope you keep eye on my thread as i'm sure i will be needing more cheering up soon
                          it was great relaxation task with my oven till yesterday when my slab cracks started
                          • stonecutter
                            • Jun 2007
                            • 2003
                            #178
                            *sigh* Read this again.....You don't have a serious problem or one that is going to ruin your oven. Watch it, and if things change you have a solution.
                            Just cure it and start enjoying it.
                            John Ruskin
                            • CrocAu
                              • Apr 2013
                              • 164
                              #179
                              thanks for that last post, it really took some weight of my shoulders at the end of quite a bad day
                              • deejayoh
                                • Jul 2010
                                • 1893
                                #180
                                As Stonecutter says, that's not going to crack your slab - but it is a surprising amount of heat going into the slab. Checked back in your thread and see you have 2 inches of cal-sil. Is that wet? Thinking that might be why your floor is not heating.
