house brick for stand, quick quetsion
  • stonecutter
    • Jun 2007
    • 2003
    #31
    Re: house brick for stand, quick quetsion
    Yeah, cooking oil is ok. You can use the hardieboard too, but it should be cut short and dropped out after the slab cures. The gap isn't really a big deal if you block it with something, even rolled newspaper. The focus is on supporting the center.
    Old World Stone & Garden
    John Ruskin
    • reccymech
      • May 2013
      • 20
      #32
      Just to 'chime' in on another fellow WFO builders thread.
      Regarding the concrete base. If I already lay a moisture barrier - builders plastic down on the slab, is it a bit of 'over egging the custard' if I lay some moisture barrier down for when I get around to pouring the base for the dome?
      I tend to over engineer 'stuff'.
        If you are talking about the structural slab for the hearth. It would be great to add another layer of plastic and/or sealer on top of it but, under the insulation layer .
        • CrocAu
          • Apr 2013
          • 164
          #34
          almost there :O
          can someone please have a look at my picture and tell me if it is ok to have particle board 10-15mm below top brick edge?
          I can bring it up but unless there is some trouble i'm asking for other than using little bit of extra concrete then I would prefer use that time on finishing up my frame box tomorrow morning.
          also i'm going to make small 25mm "lip" edge around the outside brick to hide brick<>concrete line that can look bit ugly, anything I should look out for with this idea?
          • stonecutter
            • Jun 2007
            • 2003
            #35
            Originally posted by CrocAu
            almost there :O
            Yes that is O.K. No problems with creating a small ledger either. Remember to add some kind of release to your form...that stuff will really take the water in.
            John Ruskin
            • CrocAu
              • Apr 2013
              • 164
              #36
              I have put shiny side up so fingers crossed it wont be too bad and I plan to rub it with a lot of cooking oil, should I do more? also how soon can i remove my form? i figure the longer i leave it in place the harder it will be to remove.
              also any tips on how to get top finished nice and smooth?
              now that this "thing" is taking its shape I can't believe how HUGE it is :O
              • stonecutter
                • Jun 2007
                • 2003
                #37
                I suspect you have Masonite and not particle board...at least that what it looks like in the picture. Give it another liberal coat just before you pour the concrete in...no standing puddles, just wipe it down. Leave the form for 7 days and keep the top of the slab covered with plastic.
                Once you screed the slab level, use a mag float to smooth it out. It will close up the concrete and give you more 'shine' than a wooden float.
                John Ruskin
                • mrchipster
                  • Apr 2010
                  • 1502
                  #38
                  Another good trick for a small area like this is parchment paper laid over the particle board, it can be taped on the underside at the seams to seal it together and will release very easy when you take the board out
                  Chip
                  Chip
                  • CrocAu
                    • Apr 2013
                    • 164
                    #39
                    it is subfloor board down under we call it yellow tongue
                    Chip
                    quick google indicates that parchment paper = baking paper? is that correct? if so then that is great as I got giant 300meter roll here
                    • mrchipster
                      • Apr 2010
                      • 1502
                      #40
                      Correct baking paper = parchment paper
                      Chip
                      • CrocAu
                        • Apr 2013
                        • 164
                        #41
                        thanks again everyone
                        • brickie in oz
                          • 3445
                          #42
                          It looks like it, if it is the top surface is completely waterproof for 3 months out in the weather, if its orange tongue oil it firkst.
                          • CrocAu
                            • Apr 2013
                            • 164
                            #43
                            are you saying I should worry about the baking paper then?
                            EDIT: weather stopped me today but I did get the main part of the outer frame done so need one day with good weather to finish this
                            btw I got some spare rebar and my base is little larger then most from what I seen should I add 2 extra members ? what is normal spacing 300mm?
                            • brickie in oz
                              • 3445
                              #44
                              Just spray it with oil or wd40 to be on the safe side.
                                If you are planning an igloo oven and it will be out in the weather, rather than screeding the slab off level it is a good idea to mound the supporting slab up slightly in the middle so that there is a slight slope to the outside. This prevents (to a certain extent) water from accumulating under the insulation.if you are building a doghouse style or the whole oven is covered with a roof, then screening it level is sufficient. The insulation layer sitting on top of the supporting slab should then be made flat to take the floor.
