New pre-cut kit build in Adelaide
  • Liteceeper
    • Jul 2013
    • 90
    #121
    Re: New pre-cut kit build in Adelaide
    Originally posted by applor
    Going to look fantastic with the granite bench tops in place!
    So you plan to brick all around your oven and then maybe lay tiles at 45 degree slope on the front?
    Hi Applor
    The tles will be vertical on the 45 degree corner of slab.
    Liteceeper
    My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
    My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
    "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
    • Liteceeper
      • Jul 2013
      • 90
      #122
      Just out of oven, Best bread bake so far, two sourdough and four crusty Italian white.
      Cooking six at once really kept the steam in oven.
      Will repost in what's cooking, just had to show off.
      Liteceeper
      • applor
        • Oct 2013
        • 210
        #123
        Just noticed with this kit from Ben that the door is right at the entrance to the oven and not the dome.
        Should it not be in between the dome and the flue to avoid all the heat escaping up the flue overnight?
        • Greenman
          • Feb 2013
          • 1123
          #124
          If you want to maintain heat in the dome you will need an insulated door that closes to the inner arch or seals inside the flue. There are a few different doors and it sounds like yours is not meant for the purpose of retaining heat in the dome.
          Cheers ......... Steve
          • applor
            • Oct 2013
            • 210
            #125
            Ben do you sell/make an inner door for your kits at all?
            • Liteceeper
              • Jul 2013
              • 90
              #126
              Hi Applor
              My photos may have confused you. Both Ben's door and my home built insulated door close the dome. I place the insulated door in dome and then Ben's door at front to store them out the way when not using oven.
              Liteceeper
              • ErinArdill
                Banned
                • Jul 2014
                • 1
                #127
                we had a look at a some display homes and found Format homes to be a good pick out of the lot. Also, one of my Mrs friend built a home with Weeks & Macklin and she was happy with their quotation,service and quality. I haven't heard any positive reviews for Fairmont homes so they are out of my list.
                • applor
                  • Oct 2013
                  • 210
                  #128
                  wrong thread?
