New pre-cut kit build in Adelaide
  • Greenman
    • Feb 2013
    • 1123
    #91
    Re: New pre-cut kit build in Adelaide
    That looks great. The door is very attractive and the cast section leading to the flue is a smooth look. It should be a great thing to have just in time for the festive season. I am sure that you will enjoy the rest of the journey to WFO heaven.
    I look forward to seeing the progress towards completion, it has a lot of potential.
    Cheers ......... Steve
    • Liteceeper
      • Jul 2013
      • 90
      #92
      I especially like your door and the throat for the flue.
      Thanks Stonecutter, I think the door is a nice finish of steel & timber.
      Originally posted by oasiscdm
      Hi well done looks great. Xmas roasts coming this year yum.
      What's the menu?
      Thanks for kind words Colin, I guess tongue pie on menu if I fail to finish by xmas.
      Thanks Greenman, Looks like completing ovens tends to slow once the cooking begins, I will need to stay focussed.
      I ordered the flue and dropbox from A&B Industries in Salisbury, Adelaide yesterday as my patio roof is part of the main house roof.
      I will leave oven to air dry and cure until weekend and then start ceramic blanket and perlite render.
      Once I receive the flue the firing of oven will start
      Liteceeper
      My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
      My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
      "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
      • Liteceeper
        • Jul 2013
        • 90
        #93
        Started curing oven with no insulation applied with a gas (propane) burner one Wednesday after work from 4pm to 10pm with a small flame, got to about 100C.
        Continued each night to weekend and then started all day burns with larger flame whilst doing ceramic blanket install. Placed door in oven raised on blocks to allow fire to breathe got to 250C, continued during week whilst applying perlite render and then a couple of days with fire in the hole. Thursday & Friday temps up to about 350C. Did full fire on Saturday evening to clearing dome after having gas (propane) flat out all day Saturday.
        Ended up with a couple of cracks in perlite render around flue galley, next time I would place some aluminum foil over flue galley to prevent perlite render from adhering and act as a natural expansion point.
        The render was laid one strip per day, I initially laid a 3" (75mm) strip using plastic garden edging set out from calsil with 2" (50mm) timber blocks and held in place with bricks.
        Then next day rendered between this and the 2" (50mm) corrugated conduit, in hind-sight I would have made the first strip slightly smaller about 6" 180mm.
        Let set overnight, removed conduit next day and set higher after trimming for diameter reducing. Repeat until at top where I laid strips across top to continue gauge as diameter to small for a circle of conduit.
        The render was 5:1 Exfoliators Litefill Premium Perlite and Brightonlite HE cement. I used 3.5 8kg bags of perlite and 4 20kg cement.
        Blanket held by wires ran across dome to long screws anchored in calsil board with about 6" of tail on each end of wire. I had a screw in top centre of dome which I wrapped wire around and continued to screw on opposite side when all wires in place I removed screw and tie all wires together with small piece of wire. This allowed wires to be removed from screws as blanket was wrapped around dome and wires passed over blanket. The blanket had wedges cut with large shears to allow for neat fit.
        The concrete slab cracked on the day of the clearing fire, but no cracks in oven itself. The underside of the slab got to 75C so the calsil board must have been holding a lot of water.
        Liteceeper
        • Liteceeper
          • Jul 2013
          • 90
          #94
          More photos of rendering.
          Liteceeper
          • Liteceeper
            • Jul 2013
            • 90
            #95
            Flue photos and first pizza
            Liteceeper
              • 5260
              #96
              Congrats on the first pizza and like a good wine they get better............
                • 2848
                #97
                Gudday
                Thanks for the detailed explanation of your insulation rendering. Like most of us you have used lots of ideas of those who have gone before us. So you have done you research well and certainly recognize a good idea when you see it.
                One thing that you have come up with that I have never seen is the way you have cut the insulation into triangular wedges. Now that's different!
                It certainly has its advantages. Appearance for a start, its certainly given a smoother appearance. But more importantly the lack of overlaps means its possible to to get full 2 inch cover on a 42 in dome from a single box of insulation. My own has only a 1 in cover down low on the last 4 ins of the dome. Steve70 is the last one to come to mind as well with just not quite enough insulation in a single box.
                I also like the hose idea for helping to apply the pearlcrete. I once helped someone put 4 ins of pearlite over a dome. I found it a frustrating task and very hard to get it to stick to start with, and harder to get a uniform appearance.
                Thanks again for the detailed explanation and congratulations on a job well done.
                • oasiscdm
                  • Jan 2012
                  • 1239
                  #98
                  I resemble those remarks...
                  Job well done... As they say proof of pudding is in the eating.
                  Can't tell one or two layers of blanket 25 or 50mm?
                  Cheers Colin
                  Oven 1 Completed
                  Oven 1 and surrounds
                  • Greenman
                    • Feb 2013
                    • 1123
                    #99
                    Congratulations on a good job. Every new build brings out a fresh idea or two and yours is no exception. I like the overall look of it and I am particularly impressed with the section leading up to the flue. Thanks for sharing.
                    I have no doubt that the free form pizza tasted every bit as good as it looked. Anyone can make round ones, it takes skill and artistic ability to knock out a decent random shape and the additional crust edge is the secret to the extra crunch and flavour.
                      Great job! Liteceeper,
                      Thanks!, for thinking outside of the box. Your contribution will help many future builders, who love the looks of a "perfect pompeii", decide for themselves, the ultimate question ?.............. IGLOO.................... or doghouse.
                      • brissie
                        • Sep 2013
                        • 127
                        #101
                        Fantastic job Liteceeper, all through your build you have done good work. Your first pizza look good to... yum.
                        Cheers,
                        • heliman
                          • Sep 2009
                          • 1181
                          #102
                          Anyone know the cost of the 3 kits from Melbourne Fire Brick? They inconveniently omitted this info from their website.
                          / Rossco
                          • heliman
                            • Sep 2009
                            • 1181
                            #103
                            Excellent build - most impressive attention to detail and great finished product. what is the reason for putting the "pool pipes" on the outside of the dome?
                            / Rossco
                            • oasiscdm
                              • Jan 2012
                              • 1239
                              #104
                              Hi Helliman
                              Liteceeper used them to screed his vermicrete insulation coat. Gave him the depth he was looking for. I used same idea when I saw his much simpler than other options I have seen. Works a treat.
                              Give Ben a call from Melbourne fire brick he is a top bloke and very helpful.
                              Cheers Colin
                              Oven 1 Completed
                              • heliman
                                • Sep 2009
                                • 1181
                                #105
                                Thanks for the info Colin.
                                That is a really good idea for maintaining depth and also to support the material once applied.
                                The lack of freely available pricing is a concern. It shouldn't be necessary to have to contact the company for this information. There should be a schedule of pricing, with add-ons and optional extras available to potential customers. The fact that existing customers themselves are not forthcoming with the price is also bizarre.
                                That being said, it looks like a good product.
                                / Rossco
