New pre-cut kit build in Adelaide
  • Liteceeper
    • Jul 2013
    • 90
    #61
    Re: New pre-cut kit build in Adelaide
    Time for a update, started on oven build now I have completed render (stucco) of patio in area of WFO. Cut calcium silicate board to size and laid straight on top of hearth slab. Covered with aluminium foil to prevent moisture being drawn out of heat bank too fast whilst curing.
    Next made form work for refactory castable heat bank 25mm thick, mixed, poured and let cure for three days.
    Liteceeper
    My Build - http://www.fornobravo.com/forum/f51/...ide-19729.html
    My Door - http://www.fornobravo.com/forum/9/sh...tml#post170496
    "Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
    • Liteceeper
      • Jul 2013
      • 90
      #62
      More update - sorted precut bricks and did a dry fit to check if I know what I'm doing.
      Ignore floor tiles not central to calsil outline I mucked up my centres
      Pays to do a dry fit first I guess.
      What,s the consensus do I mortar down floor tiles or bed in sand?
      Liteceeper
        • 5260
        #63
        If your castable is level and tiles fit well you should be good, no mortar, tiles need to float since they will expand and contract. If tiles need leveling, use a 50/50 mix of sand and fire clay installed with a 1/4" or 3/8" or so notched tile trowel right on your castable base. Nice looking kit.
        • oasiscdm
          • Jan 2012
          • 1239
          #64
          Hi Liteceeper
          Ditto with Russell
          Cheers Colin
          Oven 1 Completed
          Oven 1 and surrounds
          • stonecutter
            • Jun 2007
            • 2003
            #65
            Don't go too far ahead with dry fitiing, you'll find that things change once you start mortaring the brick.
            Looks nice so far, and I'll be interested to see how that castable skim coat holds up. Did you add reinforcement to it?
            Old World Stone & Garden
            John Ruskin
            • Liteceeper
              • Jul 2013
              • 90
              #66
              Originally posted by oasiscdm
              Hi Liteceeper
              Ditto with Russell
              Thanks for advise Russell & Colin but I have stuck to Ben's plans and used a mortar mix to set floor as the castable had a dip on LHS throwing tiles out of whack.
              2 refactory mortar
              2 sand
              1 lime
              1 GP cement
              I guess the bricks and floor will take up their own positions once the oven gets fired up.
              No reinforcement used but appears OK, see above quotes, it may allow some movement of floor tiles?
              Had a good weekend finally building oven, Friday afternoon laid floor, Saturday morning ground edges of floor tiles to remove slight raised edges on a few tiles, then laid first 3 courses.
              Today (Sunday) I filled wedge spaces between bricks with castable, thought best do this whilst bricks are still wet from laying them. Then laid fourth course.
              Anthony
              Liteceeper
              • stonecutter
                • Jun 2007
                • 2003
                #67
                I had made that comment thinking your castable was the finished floor. Concern about the castable is all moot, since you covered it with floor tile...I don't know how I missed that.
                John Ruskin
                  • 2848
                  #68
                  Gudday Anthony
                  Building with a precut kit... I can see the advantages of not having to worry about the arch transition etc etc. It's certainly coming ahead quite well.
                  Are you still aiming for the "oven pic " you posted earlier with the oven hearth height the same as the surrounding base. That look is certainly smart and clean.
                  Love your work
                  Last edited by cobblerdave; 11-03-2013, 04:20 AM. Reason: Spell check and your ... Don't you hate it
                  • Liteceeper
                    • Jul 2013
                    • 90
                    #69
                    Gudday Anthony
                    Love your work
                    Thanks for your kind words Dave,
                    I was surprised at progress over weekend but I guess all the hard yakka cutting bricks has been done for me.
                    Yes still planning to finish level, will place cut down face bricks around edge to finish about 30mm below hearth top surface then build up base with perlite concrete to level of bricks (-30mm) and then have some granite tops made to sit flush.
                    Not sure if perlite concrete will give a solid enough base to secure granite too, any ideas.
                    Liteceeper
                      • 2848
                      #70
                      Gudday Anthony
                      I can't see why not ..... You could upgrade the Portland cement content and add some sand as well. When you think about its not like you are trying to get the best insulation layer ... That's already there.
                      Just a thought
                        Yes the addition of sand and more cement also makes the mix easier to work and it behaves more like normal concrete to level.
                        • Awild8
                          • Oct 2013
                          • 17
                          #72
                          looking good mate, great to see Bens kit being built just before I starting putting mine together in the next few weeks.
                          • Liteceeper
                            • Jul 2013
                            • 90
                            #73
                            Gudday Anthony
                            Just a thought
                            Thanks, any suggestions on volume ratio perlite, sand, cement?
                            Liteceeper
                              For your application I'd be using 3:1:1 vermicrete, sand , cement.It will give you a lightweight concrete that's fairly strong, not a bad insulator and easy to work.
                              • Liteceeper
                                • Jul 2013
                                • 90
                                #75
                                Thanks Dave
                                Liteceeper
