D105 Pre-Cut brick kit build in Tassie
  • Steady
    • Feb 2015
    • 214
    #181
    I installed the stone hearth last weekend - all went well and celebrated with pizza on Saturday night.
    Cheers,
    Steady
    http://www.fornobravo.com/forum/f51/...ild-21760.html
      • 5260
      #182
      Nice looking stone and final product.
        • 2848
        #183
        G'day steady
        Looks great as I thought it would.
        I'm pretty impressed you've only been cooking for 6 months and you've finished it.
        • Steady
          • Feb 2015
          • 214
          #184
          Thanks UtahBeehiver and cobblerdave - I have some more work to do on the stand (render/stucco) and then I want to make some benches on either side with space for a BBQ and sink etc + some sort of covering to help get more use during the winter + some paving - I doubt I will ever finish finish :-)
          Cheers,
          Steady
            Nice work. I notice that you haven't installed a flue pipe. Although it is not really necessary apart from keeping the smoke away from your face it also creates more draw and should stop that blackening on the front of the arch opening.
            • Steady
              • Feb 2015
              • 214
              #186
              Thanks david s,
              I do have a flu - I just take it off and put an upturned bowl over the sharp stub end before wrapping it up with a tarp. If you look at the 4th photo above that doesn't show as a thumbnail it shows the flu in situ.
              Regarding the blackening, I think I am not going to avoid it. Mrs Steady is suggesting that I either paint just the arch, or all of the exposed bricks black - I am undecided but I can see her logic.
              Once it is done it would be hard to undo. They are fire bricks and I have already sprayed them in heat/flame resistant clear paint made for combustion engines etc to reduce how much water they will absorb.
              Cheers,
              Steady
                Ahh, yes I see. Far easier to cover the oven with the flue pipe off. If you want to do something about the front arch you could clean it up a bit with a wire brush and tile/mosaic it. You need to use glossy tiles, a quality outdoor tile adhesive and black grout. Any soot staining rubs off easily with some damp newspaper.
                • Steady
                  • Feb 2015
                  • 214
                  #188
                  Thanks David, I will have a look at some oven photos where the front arch has been tiled to see if like the look
                  Cheers,
                  Steady
                  • Matt Taylor
                    • Jan 2017
                    • 3
                    #189
                    Hi Steady what size was your oven stand as I'm looking at building this size as well in a corner.
                    • Steady
                      • Feb 2015
                      • 214
                      #190
                      Hi Matt, welcome to the Forno Bravo Forum.
                      My stand is 4 blocks wide x 4.5 blocks deep (nominally 1600 wide x 1800 deep)
                      If doing it again (and in a corner) I would rotate the stand 45 deg and cut the corner off, there are many examples of it being done that way on this forum.
                      Cheers,
                      Steady
