Thanks, that's why I used a thin piece of wood and not a large metal plate like on many IT designs I've seen on the forum. The pivot point of the caster is in the centre of the oven floor, and the distance between it and the bolt holding the piece of wood is constant. Regardless, I try to keep things achievable at my level and not compete with the assembly precision of a Swiss chronograph. The wooden piece is attached with screws, so it will always be possible to adjust the length on the fly. I don't rule out using an inflatable gym ball for the last rows of the oven. I don't cut the firebricks these days because my wife has spread her rice harvest in the front courtyard to dry in the sun, and these cuts create a lot of dust. Thank you very much for your valuable and wise advice.
Corner Pompei Oven following Forno Bravo instructions-Loei Thailand
A similar idea is to use a length of plastic conduit as the arm of the IT. The plastic being easy to flex can be bent which shortens it enough for the plate, which holds the brick in place, to easily remove it without having to adjust anything. Then it springs back into shape ready for the next brick.Kindled with zeal and fired with passion.
As I mentioned, the castor height is not a deal killer but most important is the projected line from the pivot point along the wood needs to intersect the center of the brick face or you end up with stepping of the brick face as you move up in courses. The error is cumulative. I marked the attached picture for another builder years ago but is is similar to the IT you are considering using.
https://community.fornobravo.com/fil...19&type=mediumLast edited by UtahBeehiver; 11-18-2023, 08:58 AM.Russell
Originally posted by UtahBeehiver View Postmost important is the projected line from the pivot point along the wood needs to intersect the center of the brick face, or you end up with stepping off the brick face as you move up in courses. The error is cumulative. I marked the attached picture for another builder years ago but is is similar to the IT you are considering using.
Artisan Made, he's also following the Forno Bravo design.
Originally posted by david s View PostA similar idea is to use a length of plastic conduit as the arm of the IT. The plastic being easy to flex can be bent which shortens it enough for the plate, which holds the brick in place, to easily remove it without having to adjust anything. Then it springs back into shape ready for the next brick.
To maintain the heat I made a door using leftover from my new solar panels array, steel 5cm/5cm filled with leftover of the ceramic blanket. The upper part is removable, the purpose is to use the chimney as a smoker with a piece of rebar on the top to hang meat or sausages... The air inlet is reduced to reduce the oxygen and produce smoke. I'll need to pay attention to not fully open the door when it's used as a smoker, causing the fire to erupt suddenly. I built some fire and it seems to work properly.
